This started as a simple design and grew into a larger design as reality set in. Now I'm looking a full on five thruster (4 lateral, 1 vertical) setup, although I might build it initially as a three thrust config with wiring in place to go to a five. I'm still debating on brushless vs bilge for the thrusters, but brushless is looking better and better cost wise.
The plan is to use on-board power along with a thin tether (fiber pair only), onboard fiber to copper converter, USB over IP adapter and a USB hub. Adding an ethernet switch would allow use of IP CCTV camera with PTZ, and I plan to run a cat5 into the camera housing for this purpose alongside the USB wire. Initially I will likely use a USB web camera, but if I ended up using the 100 Mbps fiber converters, I'm not sure the bandwidth will be good enough. CCTV IP cameras have H.264 compression and would work very well over that bandwidth. The cost to go to 1000Mbps fiber converters is about $120 total. Then USB 2.0 bandwidth is maintained.
Control will be handled by an Arduino Mega connected to a laptop/joystick combo via USB over IP. A second Arduino will handle telemetry data which could be fed via USB or Ethernet to the laptop.
Here is the concept, from which I have now removed the lighting built in to the main 4 inch tubes and will mount it as a separate module to allow for easier modification and adjustment:
And here is the actual build that I started on today!
