seal
Posted: Aug 30th, 2012, 11:10 am
by turtle
is this the same seals that are in the bilge pumps ?
adam
http://www.ebay.co.uk/itm/Black-3x6x2-1 ... 0824359989
Re: seal
Posted: Aug 30th, 2012, 11:20 am
by turtle
looks the same i might order some and see if it works.
Re: seal
Posted: Aug 30th, 2012, 11:32 am
It looks similar but Its hard to tell. I'm thinking a seal for a Pneumatic Air Cylinder Piston would/might be different because it has to seal a shaft that is moving in and out as apposed to rotating. (I could be wrong though.)
-Steve 8-)
Re: seal
Posted: Sep 1st, 2012, 4:47 pm
by turtle
i have found a good way to make a seal for the 3mm shafts on my motors :D iam using m6 stuffing glands you can tighten them to get a really good seal and it doesnt leak at all, i am going to pressure test them when i get chance this week and see what they can take. its a nice and cheap and easy solution if it works. i found this aswell while i was looking around the net.
http://www.sub-driver.com/accessories/c ... l-1-8.html
adam
