Teensy
Re: Teensy
the development environment seems to be the biggest limitation. Unless you have experience developing code for microcontrollers, I'd suggest you start with an arduino. arduinos are a little more expensive, but the cost of the boards is small when you consider the whole environment. there is an enormous wealth of info out there for the arduino. the teensy, not so much.
good luck!
good luck!
