Water right wiring through hulls?
I'm curious how everyone is getting their wiring into the hull and staying water right? I'm hesitant to just throw a ton of epoxy at something. Are there affordable water tight fittings?
asesorplaza1
Re: Water right wiring through hulls?
Buenas noches.
Si hay accesorios a prueba de agua, otra cosa distinta es que sean asequibles, supongo que te refieres a este tipo de conectores, o a algo parecido.
Pero aun así, te recomiendo que refuerces la conexión con exposi
Espero que te sirva
Un saludo.
Good night.
If there are waterproof accessories, another thing is that they are affordable, I guess you mean these types of connectors, or something like that.
But still, I recommend that you strengthen the connection with exposi
I hope it works for you.
Greetings.
https://es.aliexpress.com/item/32857543 ... 4c4dVaUNMB
https://es.aliexpress.com/item/32368634 ... 4c4dVaUNMB
https://es.aliexpress.com/item/40011498 ... web201603_
https://es.aliexpress.com/item/32950916 ... web201603_
https://es.aliexpress.com/item/32931574 ... web201603_
Espero que te sirva
Un saludo.
Good night.
Greetings.
Thanks!!
I know the IP ratings don't really do depths, but i can definitely test these out.
Thanks again.
Thanks again.
