i have this older underwater camera housing that would make to my assumption a fairly good starting point to make a ROV body. The housing is rated to 300ft and would have more then enough space to hold all the necessary components to run the ROV. Im thinking i can even pressurize the housing on the surface to give it some extra depth. the housing is pretty big tho. i dont know if this would cause any issues when it comes to picking propulsion.
My biggest challenge if i decide to peruse this is my lack of knowledge with underwater thrusters, as well as what to use as and umbilical for such depth. Im thinking that CAT5 Cable will be to short as its transmission distance is 328ft, would fiber be a better option. i dont know how much thrust the trusters need produce as well as how to waterproof for those depths.
and of course i dont know what i dont know so if any one has some extra advise to give, i would happily take it.
