Problem with Brushless Thrusters
gsisrov
Post by gsisrov »
Hi,
We've built a motor testing rig to test brushless outrunners. To record the force, turned it on for one minute and logged the force throughout the minute. After on the first round we measured 1.7N average force. After the motor was in the water for a couple of minutes, in the last test we only measured 1.4N average force. The only difference between the two runs is that the motor was in the water for longer. Are there any obvious reasons for this?
SSN626B
Re: Problem with Brushless Thrusters
Post by SSN626B »
@gsisrov,
Possible increased bearing friction after the first run in the water?
SSN626B/TCIII
puzzler300
Post by puzzler300 »
Is your prop coming loose? Mind tends to do that, you can especially tell if there is a loud rubbing/vibrating noise at higher rpms.
ROVER3D
Post by ROVER3D »
Sounds logical.
Could also be a current-leakage, a heated ESC or growing short circuit. Did you seal the coils of the Motor with some polish? Do you use motors with good quality? Did you try a third test?
puzzler300
Are you sure that your battery is fully charged?
