6-7 volt camera
6-7 volt camera
I need a 6 to 7 volt camera because of voltage drop I can't get all 12 volts I need for a backup camera down the tether I have looked at step up converters but can't find any that can fit my specifications it has to fit in a 2 inch PVC pipe any ideas
Re: 6-7 volt camera
Have you tried to power the camera from a battery located in the ROV? Some wired security camera can be run off of a 9 volt battery for a limited time.
Good luck, let us know what you find
Re: 6-7 volt camera
Look for "wide voltage camera"on ebay...
Should find what you need for about 25$
Re: 6-7 volt camera
Thanks for the replies but I found a good step up converter that fits my specs
Here it is
http://www.ebay.com/itm/NEW-DC-DC-Adjus ... 20d726ced3
Here it is
