Raspberry PI based ROV
Re: Raspberry PI based ROV
It's not a question of saying please or not,,,, its' how many pleases will it take
I don't want you to spend ages on it but if it is a quick easy job for you to knock up an example then I will indeed be most grateful.
Please, Please ...
thanks...
Please, Please ...
thanks...
Ah yes I see the bit where you've named the canvas as RovContext and then referenced that further down the script.. So I think I've go the HTML5 bit sorted now...hmmm well only the drawing stuff on the screen bit of the HTML5 the socket bit is still evading me though I am honing in of the beast...
I'm wading through java script stuff at the moment.....
Right... did some deleting on the the code... just to get a keyup/keydown socket event.
Using 3 files (server.js package.json and public/index.html)
server.js
package.json
public/index.html
Run commands
- npm install (needed for the express module)
- node server.js
server.js
Code: Select all
// Copyright (c) 2015, Eric van Dijken <eric@team-moki.nl>
var version = "0.0.1";
var express = require('express');
var app = express();
var server = require("http").Server(app);
var io = require("socket.io")(server);
/* Server config */
app.set("ipaddr", "192.168.1.128");
app.set("port", 3000);
app.set("views", __dirname + "/views");
app.use(express.static("public", __dirname + "/public"));
app.get("/", function(request, response) {
res.sendfile('index.html');
/* Socket.IO events */
io.on('connection', function(socket){
console.log('connected');
socket.on('disconnect', function(){
console.log('disconnected');
socket.on('keydown', function(event) {
console.log('Keydown request: %s', event);
socket.emit("command","ON");
socket.on('keyup', function(event) {
console.log('Keyup request: %s', event);
socket.emit("command","OFF");
//Start the http server at port and IP defined before
server.listen(app.get("port"), app.get("ipaddr"), function() {
console.log("PERFO Server up and running. Go to http://" + app.get("ipaddr") + ":" + app.get("port"));
Code: Select all
"name": "Perfo",
"version": "0.0.1",
"description": "Raspberry PI nodejs example",
"main": "server.js",
"repository": {
"type": "git",
"url": "https://github.com/Moki38/perfo.git"
"keywords": [
"Raspberry PI"
"dependencies": {
"express": ">= 4.6.1",
"socket.io": ">= 1.0.6"
"author": {
"name": "Eric van Dijken <eric@team-moki.nl>"
"contributors": [
"name": "None",
"email": "@",
"url": "https://github.com/none"
"scripts": {
"start": "node server.js"
"license": "MIT"
Code: Select all
<!doctype html>
<html>
<head>
<title>Raspberry PI Perfo (V0.0.1)</title>
<meta http-equiv="X-UA-Compatible" content="IE=Edge">
<script src="http://code.jquery.com/jquery-1.11.1.js"></script>
<script src="/socket.io/socket.io.js"></script>
<script type="text/javascript">
var socket = io.connect();
wIsDown = false;
$(window).keydown(function(e){
switch(e.which){
case 87:
if(wIsDown) return;
wIsDown = true;
socket.emit('keydown', 'ON');
break;
$(window).keyup(function(e){
command = "Stop";
switch(e.which){
case 87:
if(!wIsDown) return;
wIsDown = false;
socket.emit('keyup', 'OFF');
break;
</script>
</head>
</script>
<body bgcolor="#00000000">
</body>
</html>
Run commands
- node server.js
Thanks... I'll pick through that and see If I can learn something...
what does this bit do ?
I mean I know it is making the stuff in jquery available in this module but what do we need that's in jquery that we haven't got in the code ?
I'm afraid I still can't see what express is doing,
It looks to be doing the same thing as Node will do anyway, but never mind I'm sure I'll figure it in the end...
Thanks a lot for that Moki .....
npm install...now I see the point of package.json I had erroneously thought it was a file to send with your project to check the right versions where installed. I hadn't realised using npm install actually used the file to install everything you need locally rather than the global express or whatever... This in itself has been a handy hint....
Does this mean anything to you
Then when I try and run it I get
Code: Select all
npm WARN package.json Perfo@0.0.1 No README.md file found!
npm WARN unmet dependency /home/pi/Moki2/node_modules/socket.io/node_modules/socket.io-parser requires debug@'0.7.4' but will load
npm WARN unmet dependency /home/pi/Moki2/node_modules/socket.io/node_modules/debug,
npm WARN unmet dependency which is version 2.1.0
npm WARN unmet dependency /home/pi/Moki2/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser requires has-binary@'0.1.5' but will load
npm WARN unmet dependency /home/pi/Moki2/node_modules/socket.io/node_modules/socket.io-client/node_modules/has-binary,
npm WARN unmet dependency which is version 0.1.6
Code: Select all
module.js:485
throw err;
SyntaxError: /home/pi/Moki2/node_modules/express/node_modules/accepts/node_modules/mime-types/node_modules/mime-db/db.json: Unexpected token e
at Object.parse (native)
at Object.Module._extensions..json (module.js:482:27)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object.<anonymous> (/home/pi/Moki2/node_modules/express/node_modules/accepts/node_modules/mime-types/node_modules/mime-db/index.js:11:18)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
Never seen this error before
Which version of node and npm do you use? (node -v and npm -v output please)
And remove the node_modules directory and try the "npm install" command again.
Okay cokay..
Node version 0.10.0 I think I rolled this back to an earlier version to get it to work with your rov software..
NPM version 1.2.14
I deleted node_modules and re run NPM install. All seemed good with no errors so I re tried
Node server.js and got
however that was caused by me being thick... I had reinstalled server.js but not changed the IP address...
So deleting node_modules and re doing npm install fixed it.... I'll go and play now....thanks
NPM version 1.2.14
Code: Select all
events.js:72
throw er; // Unhandled 'error' event
Error: listen EADDRNOTAVAIL
at errnoException (net.js:863:11)
at Server._listen2 (net.js:989:19)
at listen (net.js:1030:10)
at net.js:1104:9
at dns.js:72:18
at process._tickCallback (node.js:415:13)
at Function.Module.runMain (module.js:499:11)
at startup (node.js:119:16)
at node.js:903:3
Code: Select all
ReferenceError: res is not defined
at /home/pi/Moki2/server.js:18:9
at Layer.handle [as handle_request] (/home/pi/Moki2/node_modules/express/lib/router/layer.js:82:5)
at next (/home/pi/Moki2/node_modules/express/lib/router/route.js:110:13)
at Route.dispatch (/home/pi/Moki2/node_modules/express/lib/router/route.js:91:3)
at /home/pi/Moki2/node_modules/express/lib/router/index.js:267:22
at Function.proto.process_params (/home/pi/Moki2/node_modules/express/lib/router/index.js:321:12)
at next (/home/pi/Moki2/node_modules/express/lib/router/index.js:261:10)
at SendStream.error (/home/pi/Moki2/node_modules/express/node_modules/serve-static/index.js:107:7)
at SendStream.EventEmitter.emit (events.js:95:17)
Not sure, but replace "res" with "response".
See if that helps, i think it will.
