Rasp Pi as web cam server
Re: Rasp Pi as web cam server
Hi Moki,
Which version of the PI are you using? Because the A version is a bit to limited for this is my experience. Also an important factor is the camera you are using and which output it supports. Since this determines the amount of CPU power the streamer needs to "convert" the data.
Fryslan
Fryslan
I started with the B version... (and after some water damage
), am now using (multiple, as in client/server setup) B+
Have tested the Raspberry Pi B+ with 4 Logitech C525 webcam streams (max 2, without USB powered hub), it slows down (40-45% CPU)... but still keeps on streaming (guess about 15 fps).
![Fishy <><](./images/smilies/icon_fishy.gif)
I can't believe I missed this post from WAAY back. I actually just got this exact webcam and was going to try streaming (because the pi cam is pretty slow).
Moki, can you help me out here? I think I got it all set up except for the index.html. Is that file supposed to exist already? If not, can I get a copy of it from somewhere else? If I try typing all of that I'm sure to fudge it up.
(also, I added 'sudo' to the beginning of a few commands here, my default permissions wouldn't work for it, so I wanted to let anyone reading this in the future they may have to add that.
Is this code and set of instructions still accurate? Would you do it differently today now that you've been doing this for a while?
This is where I got lost... Is this file supposed to exist already? This is a lot to type in, and I'm likely to mess it up. Can I copy it from somewhere else and update?Moki wrote:Just build a new PI, with 2 Logitech C525 webcams.
This is how I did it:
Code: Select all
sudo apt-get install libjpeg62-dev sudo apt-get install cmake sudo apt-get install apache2 sudo apt-get install subversion git clone https://github.com/jacksonliam/mjpg-streamer.git cd mjpg-streamer/ cd mjpg-streamer-experimental/ make make install cd\ sudo cp /usr/local/www/javascript_simple.html /var/www export LD_LIBRARY_PATH=/usr/local/lib mjpg_streamer -b -i "input_uvc.so -n -f 25 -r 640x480 -d /dev/video0" -o "output_http.so -n -w /var/www -p 8080" mjpg_streamer -b -i "input_uvc.so -n -f 25 -r 640x480 -d /dev/video1" -o "output_http.so -n -w /var/www -p 8081"
edit /var/www/index.html (Replace <PI_IP_ADRESS> with your Pi's IP.)Open your webbrowser, go to: http://<PI_IP_ADRESS>Code: Select all
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en"> <head> <title>Moki ROV</title> <meta http-equiv="content-type" content="text/html; charset=iso-8859-1" /> <link rel="stylesheet" href="style.css" type="text/css" /> <!--[if IE 6]> <link rel="stylesheet" href="fix.css" type="text/css" /> <![endif]--> </head> <body> <iframe frameborder="0" scrolling="no" width="640" height="480" src="http://<PI_IP_ADRESS>:8080/javascript_simple.html" name="imgbox" id="imgbox"> <p>iframes are not supported by your browser.</p> </iframe> <iframe frameborder="0" scrolling="no" width="640" height="480" src="http://<PI_IP_ADRESS>:8081/javascript_simple.html" name="imgbox" id="imgbox"> <p>iframes are not supported by your browser.</p> </iframe> </body> </html>
Wait... What....
You are typing the code, instead of copy/paste?
You may want to find a terminal program, like "putty". And start using that
And i wouldn't change it, there is no need. All it does, is put the webcam stream into an iframe
I used a Pi Cam with the PI a year or so ago and streamed that to a VLC front end. It can't have been that difficult as I did it ![Smile :)](./images/smilies/icon_e_smile.gif)
Using the PI cam rather than a USB cam seemed to get much better resolution and frame rates for less CPU.
I can try and remember what I did if you need me too ?
There is a package for the pi cam in combination with uv4l which also has the option for a webserver. No hassle to install and almost no CPU usage.
http://www.linux-projects.org/modules/s ... e&artid=15 the man page of the business stuff.
I'm using putty, but forgot there was a 'front end' on Raspberry Pi.Moki wrote:Wait... What....
You may want to find a terminal program, like "putty". And start using that![]()
Thanks, I'll check it out.
That would be cool. My first preference would be to use the pi cam, but the setup I'm using has a noticable lag and I want to use it to navigate so I was thinking USB (and low res) for navigation and then activate the pi cam to record to the SD card when there is something record.perfo wrote:I used a Pi Cam with the PI a year or so ago and streamed that to a VLC front end. It can't have been that difficult as I did it
Thanks, I'll check that out too!fryslan76 wrote:There is a package for the pi cam in combination with uv4l which also has the option for a webserver. No hassle to install and almost no CPU usage.
There was a lag with the PI cam but it was pretty minuscule. If you waved your hand in front of it you may just notice the screen is behind a little but I seem to remember it was pretty good...
I'm sorry, can you help out a Raspinoob (as opposed to user of NOOB on Raspberry Pi).Moki wrote:Wait... What....
How would I go about getting that file onto my Pi.
When I use Putty to log into my Pi, it's in the command prompt and I don't use the GUI at all (and don't know how to start it).
