Hi
I am planing on building a ROV and I was wondering if this will be a good camera for it?
Here is a link http://www.bonanza.com/booths/az_seller ... Camera_New
If not what would be?
ROV Camera
soulreaper
Re: ROV Camera
It seems like it will be fine. According to the description of the camera, the worse that could happen is it could give you false colors of vegetation in low light conditions because of the infrared. At least it has infrared.
- thegadgetguy
Re: ROV Camera
You'd have to build a housing for it. Other than that, the only problem I can see is that the infrared lights on the camera body might glare off of the clear part of your waterproof housing that the camera looks through.
Re: ROV Camera
I was already planing on building a housing out of PVC.I am planing on one like the light housing on the seafox retrofit but with 1/4 inch plexiglass for the window.
- thegadgetguy
Re: ROV Camera
Yes, they work well and are fairly easy. I've built two of those so far.
Re: ROV Camera
I am building one for the lights now. I am planning on testing it in a week.
