Bubbles wrote:How big scuba tank are you planning to use?
Scuba tanks are heavy.Any estimation about total weight of the system?
bubbles,
Scuba tank is not an issue, since those tanks have great pressure inside so they contain a lot of air. Even the smallest one will do.
Current estimations are as follows:
ROV volume = about 10 liters (so that I can work easily inside it)
ROV weight = about 9 kg (so that when you leave it on the water, almost all of it is in the water, so that little air needs to be released for it to dive)
scuba tank = 1 lt, 200 bar, cost about 115 Euros new, weight 1.7 kg.
EDIT =
This one:
http://must-dive.gr/eshop/index.php?mai ... 41a089daa9
END EDIT
This contains 200 lt of air. At 90 meters depth (10 atm) the ROV must be filled with 9 (volume) x 10 (pressure) = 90 liters of air.
So there is enough air in the tank for the ROV to go 90 meters deep, surface, then dive again, the re-surface.
Since the typical "mission" will consist of going down there, do the job, come up, there is plenty of threshold.
Also, a 3 liter scuba (600 liters) can be used, for even more air.
In the initial tests (swimming pool, 3 meters deep), I will be using a fire-extinguisher, which can contain 10 bar (they work at 15-25 bars normally). I will pump this up with an aluminum 11 bar bicycle pump (its an average pressure for bike tires, they go as high as 25 bars). I am currently investigating how to "connect" the extinguisher to the valve and the pump (need some adaptors and looking for them).
bigbadbob,
sorry I did not understand what you said about pressure. It seems you warned me about a "runaway" dive effect. Im sorry, I thought you meant something else. Indeed as I said a runaway dive is possible. The pilot must be alert and slowly release air into the hull, while diving. But not too much so that the dive does not stop. Its tricky, but with the correct input about where the waterline is, it can be done. (dont ask me how, I dont know yet!) --->
suggestions welcome
As always, suggestions are more than welcome!
EDIT
PS : In the example above, Im not sure there will be enough pressure left in the tank to resurface a second time (it will require >10 bar left to counter the pressure and be able to "inflate" the hull). But anyway you get the idea, there's no problem with the weight/size of the scuba tank. Unless you want to send something really small, really deep. Then the scuba tanks needed will become comparable to size and weight of the ROV itself.
END EDIT
