I am working my way through the forum...however, one specific question has been nagging at me...
First, to set the mood:
I am designing an ROV to go to depths of 300-400'. Deep for a Minnesota native I know!
Without further ado...
Does air in chambers affect buoyancy at depths due to changes in the water temp that will drop the internal air pressure?
I'm referring to potential air in the camera or electronics chambers, etc. For shallow depths I imagine this is not too much of a factor as the temp may not vary as much. However, when water temps are at or getting near 33 degrees the internal pressure drops regardless of the pressure the container can take, no? I'm a diver and notice this with my tanks...maybe it's not too much of a factor in an container with uncompressed air (less volume to change), or perhaps just doesn't affect buoyancy as the water displacement isn't changed? Just need to get my head wrapped around this...
I talked to someone at Seabotix a while back and although I wasn't 100% sure I was talking to a tech savvy person they did tell me that they vacuum all the air out of the unit.
Does anyone vacuum any of their electronics or camera compartments? If so, do you have any good tips as to the techniques used and how to ensure the air is out without creating too much of a negative pressure?
Additional questions would be around the electronics and the performance in a vacuum chamber...sensors, relays, etc.
Appreciate thoughts anyone may have on the subject! I might get to sleep easier again soon.
Thanks!
~newbie and tinkerer extraordinaire
long post I know...but it's an an intro one...
