Hello guys, i'm trying to build my very first ROV. First of all, i'm working on thrusting. I got this guy,
http://www.hobbyking.com/hobbyking/stor ... 850kv.html , and as a propeller, i got the propeller of a fan. But, it didn't work out well when testing in water. The motor stopped as soon as i speed up a little. I have a lot of things as my suspect of this failure. The propeller or the rpm of the motor? I'm aware that the pitch of the propeller i used is quite big though.
Plz give your advice on my case.
The expected dimension of my ROV is 50mmx30mmx35mm, around some where there. Expected depth to dive is around 3,4 m. I would like to know which dia, pitch and no. of blades of propeller should i use in vertical thruster. Plus, which KV and Watt motor do you suggest to use? Btw, i'm planning to use 3 brushless dc motors, one for vertical and two for fwd/rev.
Hoping for your advice.
