Kale wrote:Hi Marius,
The RC controller has 6 channels. I wonder if that is enough to control 3 thrusters with reverse AND pan/tilt servos for a camera?
/Kale
I am controlling 4 thrusters.
2 vertical thrusters (running on the same ESC)
2 horizontal (these are connected to a Sabertooth 2 x 25 Dual 25A Motor Driver) (
http://www.robotmarketplace.com/product ... 25-RC.html )
I use ch5 to turn on/off lights
I use ch6 to tilt camera(no pan)
But if you want an p/t i would choose a different tx. Because you will not be able to control the p/t with the to other channels.
On the controller you have ch5 and ch6, ch5 is only on/off and ch6 is adjustable both ways.
Hope this helps
