Hi Guys.
Rovdude, the Digikey parts are either TX or RX (transmitters or receivers) not both combined in the one fibre, so you would need 2 fibres. Still, with a bit of research, a hobbyist could build some sort of converter from the parts. The ROV control and return data (compass, depth...) pretty easy but the video would have to be or be converted to serial data in a format that, in your case, could be decoded by the PC. USB comes to mind but I think the time delay in a long fibre (or copper cable) would upset things and not work. I've never done anything with USB so maybe check that out for yourself.
I get a feeling that there may be some confusion regarding "cat5". Basically Cat5 is just a physical specification for a type of twisted pair cable. It's common use is for Ethernet, but is also commercially used for lower speed data such as RS485 etc, also analog audio such as telephone, and of course analog security system video as used in many ROVs here. So the cable type will not come into the equation when looking at fibre stuff. The type of data into and out of the converter is what to look for in the specs.
I revisited the two links I posted earlier. The first one I managed to find a price on the "topside" component, which was listed by a distributor as $950 - no way. Irrelevant now what the ROV end costs. The second one, I had a look at the data sheet
http://www.avexcctv.com/previews/downlo ... r_1101.pdf , this looks to me exactly what we want. If nothing else the data sheet makes sense.
Ross
