Hull Crawling Vehicle
- TigerShark
Re: Hull Crawling Vehicle
Beautiful design! I think cable glands should work fine and you could use aluminum or plastic enclosures with o ring seals. What prop is that you are using? It looks like a really good size, did you modify it?
ScottishTom
@TigerShark,
Thanks very much, and like the idea for the plastic enclosures, will try that.
The propeller is a 4 Blade 95mm OD boat prop I bought from "Cornwall Model Boats" and only modification I did was drilling increasing the through hole size to about 10mm and cut two small tags off the bottom. Unreal power from it through that Outrunner Motor!
Cheers
Tom
Cheers
Tom
