@ Oldsirhippy, I too wonder about that? But never let reality get in the way of a dream
. The only one who has done the Fibre optic stuff is rover3d using ST/ST connectors, I have asked him if they are water proof enough, but no reply as yet.
I figure at worst case I would need to have the Fibre potted into my ROV so it is always attached to the Tether, but my preference would be to have a connector on my rear bulkhead, this would have a short patch lead going to the transceiver inside the ROV then on the outside would be a waterproof connector to attach the tether. There are some IP68 fibre connectors available.
@ Ross,
I hadn't seen any on ebay, must have not used the correct search terms. I see that it is also from Shenzhen, Guangdong in China. That appears to be the Fibre hot spot in China.
I would be asking a lot of questions and ask to see photos of both units front and back, you see the unit on the bottom does not have the data ports shown, they MAY be on the other side? For the minute I will let my fingers cool a while and keep playing with the code.
The code is taking a little time but that is due to trial and error, sending files back and forth. The seller told me up front it would not be easy because I had the hardware and he couldn't just do quick checks and carry on, but we are getting there, I have just downloaded his latest up date so will try that afterwards. I think he is also learning a bit as we go along, it's not everyday you program a ROV.
So far we have changed the steering from Tank mode to using a single joystick and at the moment we adding in my pressure sensor and a auto depth hold function, yesterdays stumbling block was getting 2 way comunication established to report Depth to the LCD, my guess is that today we will be fine tuning the depth hold.
Hopefully I get to wet the ROV today
