I have been trying to find information on using some unused boat stuff I have but not really seeing anything that I can understand.
I would like to connect a depth only type of transducer to my ROV so I know the distance to the bottom, this would then allow some fancy programming (by others smarter than I) to have a maintain current depth function
The other item I would like to fit is a paddle wheel that comes standard with many echo sounders, this could provide water speed when on the move and current when parked on the bottom. Not real important information, but of interest none the less.
Every thing I have found with regards to NMEA is in relation to GPS or when transducers are used they are connected to PCs.
So any ideas of
a) is it doable and
b) if so how
c) else forget it
