thanksCLYON wrote:Everything needs to match. Only run 24VDC to the motors. Only run 12VDC to the relays. As said before, you are exceeding the capacity of your equipment. If your power is 48VDC, you will have to convert the voltage for the motors and relays.
Chuck
Dc Motor Problem
eng.hossam
