Thanks for not lambasting me as a crazy person.
There are a few reasons but mostly the reason is because I want to come up with a design that will not expose the motors to the pressure and the salt water. I think most of the designs I've seen have been either a) not very powerful, b) not very reliable at depth/after being exposed to the salt water for long periods of time, ie, they leak or start consuming large amounts of power or c) very expensive for a homebuilt project.
I'd like to address all of these issues, but mostly the fact that sealed units are pretty expensive and I think there should be a cheaper option.
Another reason is because I love the challenge of coming up with a new way of doing things and if the design is good and cheap, maybe others will want to try it.
My camera design is going to be a little different from what I've seen elsewhere, the communication system is similar but unique. The interface will be a custom program I'm writing to work with wireless XBOX360 controllers and the thrusters seemed like an interesting challenge too.
Stay tuned for version 2.0 btw. I have another iteration in the works that will incorporate what I've learned here and I think it will work much better.
Imagine being able to build a completely sealed thruster unit out of a bilge pump, some printed parts and some schedule 40 PVC (rated at 280 psi if the printing on the side of it is accurate). I think the cost could be under $30 per thruster complete and it would be rated for well over 100 feet of depth.
