i also picked up some 50mm 50watt halogen bulbs and some 35mm 35watt, i dont no which ones iam going to use yet it depends on what housing iam going to use but i picked up this tube that the 50mm ones fit in. i think i might cut the threads off and glue them to the aluminum housing i am making saves me messing about on the lathe for hours.
heres a pic of the joystick i ordered i think it might be a bit to big, but i might turn it down and mod the bottom for a speed control.
this was the bilge pump i ordered off the net but after i cut it apart i found it to have cheap rubber seals. iam not going to use this, now iam going to make some custom housing and seals. but i might use the motor out of it for something its 12v 6000rpm and 6amp max.
will post some more pics soon.
adam
