hi from the uk
turtle
hi from the uk
Post by turtle »
hi all my names adam iam from the uk and ive been looking into building an rov.
ive started to order a few bits for my build so far ive ordered a HD 720P Waterproof camera and the bildge pumps but iam going to make some sealed housing later with better motors.
the only thing iam having probs with is getting the glass dome for the front but i have ordered some dummy cctv domes to take apart and see if there any good.
my plans is to use some plastic tube to put the camera in and use side thrusters and one cut into the middle of the tube for up and down thrust. ive got a 7in lcd screen that i can use from the av output of the camera. but now iam just waiting for all the parts to arrive so i can start making it lol.
adam
Mareike
Re: hi from the uk
Post by Mareike »
Hi,
my dad brought me from his job in the uk some 6mm Plexi with A 200mm disc = 10 GB. I use a piece of a 200mm PVC Pipe, cut in one of the caps a window and mount it on the pipe by using O-Rings on both sides. The cap will be used as a kind of flange.. that will do for 100m and deeper..
I am looking forward to see some Pics about your ROV building process.. You will find some helpful Infos here by going through the pages..
Welcome
Mareike
turtle
Re: hi from the uk
Post by turtle »
Mareike wrote:Hi,
Welcome
Mareike
thanks for that ive just seen some discs on the bay of e, they have them in any size upto 5mm thick. i really want a dome tho so i can tilt and pan the camera and get a good view as my plan is to over weight the rov so it can sit on the bottom and just look around. but the disc ideas sounds a lot easyer lol.
adam
Mareike
Re: hi from the uk
Post by Mareike »
I would stand off to overweight it. The reason is that your props will blow to the ground with every movement and if no current is present, it takes ages the clear the sight. Better is always a very small updrift and correct by using the motors. I will make you more flexible and keeps the view clear..
Lots of Lads here who work with real ROV's confirmed this..
bigbadbob
Re: hi from the uk
Post by bigbadbob »
I too started with a 720p camera and when i ordered dummy cctv cams for their domes i found a good working camera in one of them. so now i use a flat disc instead of a dome. how do you plan to pan and tilt your 720p cam?
I have flown an overweight ROV (2 tonne in air. lol) and it was a pain if the tide was behind you as you definately stir up silt with a thing that size.
turtle
Re: hi from the uk
Post by turtle »
bigbadbob wrote:I too started with a 720p camera and when i ordered dummy cctv cams for their domes i found a good working camera in one of them. so now i use a flat disc instead of a dome. how do you plan to pan and tilt your 720p cam?
hi
ive went with a flat disc until i can find a dome, ive ordered a 10mm thick 150mm dia one. the tlit and pan i am going to use servo motors from an rc car the bracket are cheap off the net.
i have started building it now i will put some pics up tomorrow.
adam
Mareike
Re: hi from the uk
Post by Mareike »
10mm? wow even 3mm x 150mm will hold 16 bar.. That window is torpedo approved..
Pan/Tilt: http://www.hobbyking.com/hobbyking/stor ... duct=11442
check that one out, you won't get a cheaper one
Mareike
