Description of my ROV.
Weight: About 35 lbs
Frame: 12"x12". 1/4" alum plate frame top and botton.
Flotation: 4"PVC
Camera: Sony 420P color
Main Propulsion: 30 lb thrust Motor Guide trolling motor.
Steering: Magnetically coupled rudder
Elevators: Magnetically coupled
Lights: 2 ea 400 candle power LED 4 watts @ 12v (these are bright!)
Dive Bladder: 10 in wheelbarrow inner tube.
Umbilical: 5/8 in x 70 ft
Forward speeds: 6
Reverse Speeds: 2
Water Protection: Pressurized system. (tested to 4o psi)
Controls
Steering: DPDT momemtary switch
Elevators: DPDT momemtary switch
Thrust: Original MG control switch (modified)
Video: CAT-5 with baluns (has a great picture with no interference)
Dive Bladder: 1/4" PVC Tubing
Air Compressor: 12 v 300 psi (mounted in console)
I have done some preliminary flotation tests. I will maintain pressure just above the .44 psi for each foot of depth in salt water so that pressures are never high on the system. Right now the ROV has positive flotation. I will add just enough weight to cause slow descent. Any inflation of the air bladder should cause ascent with assist by the elevators. I will be operating in currents up to 7 mpi at the mouth of Mobile Bay. I wanted an ROV that I could set down on the bottom and not move. I haven't tested the ROV in the pool yet other than flotation, ballast and leakage. I am a few days from full power sea trials. I am still putting together the control console. I have had to build each of the air tight thru-bulkhead connectors for the electrical connections.
Not sure if these images will post but I will try.
Latest
Front
Left
http://a1.sphotos.ak.fbcdn.net/hphotos- ... 2668_n.jpg
Rear
Rudder Linkage
Elevator Linkage
Lights
