Who Sells Slow Cure Epoxy?
Any miscellaneous pieces and parts that don't fit in the above forums.
rehoward
Post by rehoward »
Hi all,
I am shopping for a small quantity of slow curing (like several hours) low viscosity epoxy that will hold up in salt water when cured. Any ideas?
Randy
SSN626B
Re: Who Sells Slow Cure Epoxy?
Post by SSN626B »
rehoward,
Try using Loctite Marine grade Epoxy: https://www.bluerobotics.com/store/tool ... ine-epoxy/
It can be applied with a syringe using either 15 or 18 gauge tips.
It sets up in about 3 hours and is fully cured in 24 hours.
You can buy it at Home Depot for around $5.50 USD.
SSN626B/TCIII
