Net Tool For ROV
Posted: Mar 27th, 2012, 7:17 pm
by jcawesome
I have an idea for a net attachment!!If you found some way to run some stiff rope through a net made with the mesh doubled over so it makes a loop and wound the rope around some sort of spool attached to a motor then you could open and close the mesh. Or you could attach a motor to it so it could rotate and close the net that way. Any ideas accepted.
From,
Josh
Re: Net Tool For ROV
Posted: Apr 9th, 2012, 2:19 am
by ltdcruze
May you please post a picture? I have been looking how to make an effective mesh.
Posted: Apr 9th, 2012, 3:49 pm
by jcawesome
The way I think is best is this(you will need fine mesh):
Cut a very elongated oval out of the mesh and split it in two
Measure the edge of the flat side and multiply that by two
Cut a strip of light cloth the a little longer than that
Sow the two halves of the mesh together tightly leaving the opening well, open
Fold the strip of cloth in half over the opening and hot-glue or sow them together
Hope it works,
Joshua :geek:
