My custom LED lights
Illuminating the Abyss.
steve918
Post by steve918 »
Below are some pictures of my custom LED design. I had quite a few super bright white 5mm LEDs lying around and designed a simple circuit board for them which fits snuggly in 1" PVC. The bottom photo shows how I extended the leads through (and soldered to) an identical PCB to give the fixture a bit of stability inside the pipe.
I'm going to have two of these lights on my ROV and they should provide ample light and are only drawing 230mA (for both lights) off a 5V circuit.
The purple PCBs were made by Laen's Dorkbot service which I highly recommend: http://dorkbotpdx.org/wiki/pcb_order
Eagle files available freely here: http://cl.ly/2b0t2j2v3K2w0g3n1X2o
AHarris
Re: My custom LED lights
Post by AHarris »
I really like the LED Circuit Board, I am guessing the light shall have a screen over it?
steve918
Post by steve918 »
AHarris wrote:I really like the LED Circuit Board, I am guessing the light shall have a screen over it?
In the first picture there is a piece of 5.6mm lexan sandwiched against the o-ring using this method http://www.homebuiltrovs.com/howtosimplehousing1.html
AHarris
Post by AHarris »
Oh sorry, didn't notice it. I can see it now, very clean :P
Rover
Post by Rover »
Nice looking lights.
How did you get the power wires out of the housing? Did you pot the wires or use a connector of some sort?
Jim
