Rule 25d bilge pump shaft adapter and prop
Posted: Jun 3rd, 2016, 3:22 pm
by schaefer72
Hi new to forum. been looking thru threads for days but still need some help. building first rov. have the rule 25d bilge pumps 500 gal. per hr. what props and prop adapter should i get ?
any direct part numbers or links ?
plan on using arduino with xbox controller to control rov
any and all help appreciated
here are some of the misc parts i have so far
3 rule 25d bilge pumps
1 robot arm claw with pinch and rotate for arduino
1 sainsmart L293d motor drive shield for arduino
1 sainsmart 2 channel relay module for arduino
1 arduino uno mega 2560 r3
1 waterproof temp. sensor ds18b20 for arduino
1 kootec gy521 gyro & accelerometer for arduino
1 sainamart usb host shield for arduino
1 wired xbox controller
thanks alot
Re: Rule 25d bilge pump shaft adapter and prop
Posted: Jun 8th, 2016, 10:36 am
I found the Robbe 3 Blade 50mm prop to be the best suited for most of the bilge pumps I've tested. I custom make my own adapters but if you don't have that ability I believe someone just posted some they bought recently that worked well. I don't remember who posted it but try searching the forum and you should fine it.
