hello everybody,
after a couple of hull failures last year (water leaking in the end cap) i want to get rid of the 4" housing i have been using its quite big and the screw on cap is just annoying me and i would like a smaller and easier to open watertight box, i have seen people mention otter boxes and was wondering if anyone had used them and how they set them up pics would be great?
many thanks
John H
otter box
Re: otter box
Water leaking in the end cap is ussually the result of the threads not being sealed. Try wrapping the threads of the end cap with at least 6 layers/windings of Teflon tape, this will usually fix the problem. (although PVC end caps are still a PITA
Re: otter box
hello Steve, yea have done that and it worked i just dont like it and want something neater and as you say less of a pain
cheers
Jonny
cheers
Jonny
Re: otter box
I am using otterbox in my ROV. They are a pretty good solution as they can be opened and closed very easily with just two clips. I would recommend them to anyone who is looking for a safe waterproof housing. However they do add a lot of buoyancy to the ROV.
- ROVEnthusiast
Re: otter box
What did you use for your wire penetrators?
