Page 1 of 2
Arduino compatible depth sensor
Posted: Nov 16th, 2012, 1:49 am
by rovdude
I'm looking for an Arduino depth sensor, and any information on where the pins of the sensor go. I do not currently have a board, and have no prior experience with Arduino, so any help is appreciated. If anyone knows what the general code might look like that would also be helpful.
Re: Arduino compatible depth sensor
Posted: Nov 17th, 2012, 10:59 pm
by bikerbones1968
Will let you know as soon as I can figure that out myself.
I am researching for information but its not that easy finding ROV "parts", you almost always have to adapt something for these things every time you have an idea.
Posted: Nov 17th, 2012, 11:46 pm
by rovdude
Thanks bones. Been doing some research myself too. Found one that would work but wouldnt make it all the way to the 100 ft i want to reach. However i did find one of these would probably be sufficient:
http://www.digikey.com/scripts/dksearch ... &PV144=592
The second one in particular because it has the correct input voltage and gives an analog reading. I saw several of these sensors with more than just the 3 pins needed to connect to the Arduino, usually 6 pins on them, but I found out u can just leave then out. Hopefully this applies to this 4 pin one too. Do you know anything about this? I know one is needed for input voltage, one for ground, and one for signal(analog), but can one be left out like on other examples ive seen?
Posted: Nov 21st, 2012, 4:16 pm
by rovdude
So at digikey I contacted a tech and they said the first pin is used for supply, pin 2 for analog, and pin 3 for ground. All the others(there are actually 8), are not used
The link for the sensor is at:
http://www.digikey.com/product-detail/e ... ND/2178295
Posted: Jan 21st, 2013, 9:21 am
by jconduto
I am using the MPX4250AP and you can buy from DIGIKEY.
I can send you the Arduino code
Posted: Jan 21st, 2013, 11:47 am
by adambrum
How are you waterproofing these sensors ?
Posted: Jan 21st, 2013, 2:13 pm
by rovdude
I'm using the ASDXAVX100PGAA5 through digikey... heres my code stripped of everything else
float depthVolt, depthPsi, depthFeet;
depthVolt = analogRead(depthSensor) * (5/1024); //Takes 0-1023 reading and converts to volts by finding volts per unit
depthPsi = (depthVolt/0.04); // Depth Sensor Honeywell A Calibration: 10%-90% of supply voltage
depthFeet = (depthPsi) * 2.30665873688; //(PSI) * conversion factor
Serial.println(depthPsi + " PSI");
Serial.println(depthFeet + "Feet");
I'm putting mine inside of a drybox otterbox. They are good down to 100 feet, which is exactly my target. My arduino boards(using 2 because a light sensor is messing up the readings and timings for everything else I am using), the motor shield, and a breadboard along with all of my sensors will be housed in there. Hopefully.....hopefully the pressure is proportional inside the box as is outside.
Posted: Jan 21st, 2013, 4:44 pm
by fluxno
rovdude wrote:
I'm putting mine inside of a drybox otterbox. Hopefully.....hopefully the pressure is proportional inside the box as is outside.
the pressure inside will remain at zero pressure until water comes in
a closed container is called often "atmospheric container" meaning that the pressure inside is equal to atmospheric pressure.
you need to connect a hose to the pressure inlet, and to the outside/water. but.... the sensor youve got is only for air. it has exposed wires inside where it measures the pressure.(see page 4 in datasheet)
Posted: Jan 23rd, 2013, 10:56 pm
by rovdude
the pressure inside will remain at zero pressure until water comes in a closed container is called often "atmospheric container" meaning that the pressure inside is equal to atmospheric pressure.
Thank you for the information before I tried it lol. Now for the solution.... well I will have to think about that. When I come up with one will post on here.
Posted: Jan 23rd, 2013, 11:14 pm
by rovdude
Maybe... just a thought right now, have the sensor in a bag of air. The air in the bag, I would assume, would have the same pressure as outside the bag. As long as the bag is not completely fillled with air, I think it would proportionally and directly react to pressure. Or put the sensor in a waterproof bag without excess air. Not sure, just spitting out ideas.
