Page 1 of 3
Lipo monitor
Posted: Oct 5th, 2012, 3:15 pm
by electronicscrazy
Does anyone know how i can monitor the voltage of my onboard lipo batteries with my arduino?
Re: Lipo monitor
Posted: Oct 5th, 2012, 4:36 pm
by bikerbones1968
Re: Lipo monitor
Posted: Oct 5th, 2012, 4:40 pm
by electronicscrazy
So i would need 3 of these for a 3s battery, but the arduino uno only has only 1 i2c interface so that probably won't work.
Re: Lipo monitor
Posted: Oct 5th, 2012, 4:47 pm
by bikerbones1968
3S oh ok I will see what I can find.
Re: Lipo monitor
Posted: Oct 5th, 2012, 4:51 pm
by bikerbones1968
I gather you are not connecting your batteries in parallel and using one pack per motor? How many packs total?
Re: Lipo monitor
Posted: Oct 5th, 2012, 4:57 pm
by electronicscrazy
I'm thinking of using 4 5000mah batteries wired in parallel, and also i thought of wiring the balance plug of the batteries to the analog inputs of the arduino mega using a voltage divider.
Re: Lipo monitor
Posted: Oct 5th, 2012, 5:05 pm
by bikerbones1968
Well if your packs are wired in parallel then you really only need one sensor on the mains. When lipos are in a parallel bank its just like one big pack anyway. 4 - 3s 5000 mAh packs become one 3-s 20000 mAh pack. As I understand it if all packs are equally charged with a ballance charger they will always (in a parallel configuration) discharge equally. No one pack will discharge faster than another.
Re: Lipo monitor
Posted: Oct 5th, 2012, 5:11 pm
by electronicscrazy
So what do you suggest i use to monitor the pack voltages?
Re: Lipo monitor
Posted: Oct 5th, 2012, 5:21 pm
by bikerbones1968
You could go this route. There are many options of sensors designed for Arduinos.
http://www.emartee.com/product/42082/Vo ... Compatible
Re: Lipo monitor
Posted: Oct 5th, 2012, 5:30 pm
by electronicscrazy
Would something like this work?, and i can measure the current draw:
http://www.coolcomponents.co.uk/catalog ... p-433.html
