Magnetic coupling Thruster design (Some big challenges!)
Posted: Dec 14th, 2010, 6:20 pm
Hi there Deepsea explorers.
I am still gathering information on my hobbyproject and trying to get a proper design up for prototyping and testing for my longterm ROV build.
I try to share some of my experiences and hope that some of you might help out as well.
If any of you have some interest in working together withe me on developing an opensource model for a magnetic thruster feel free do drop me a PM or reply below
After ALOT of reading about different approaches to building my own ROV Thruster i made my mind and am avoiding the bilge pump thruster method and going for the more heavy design.
Using a magnetic coupling to connect the propellershaft to the motorshaft and by using a smallscale brushless dc motor and a ESC motordriver i plan to take on much heavier depths than i could using either the O-ring, Face-seal or lip-seals on the thruster housing.
There is alot of commercially availiable couplings allready built so this may be an easier approach than building the whole system from scratch.
Since the brushless motor is designed to work when submerged in mineraloil the possibility to flood the motor housing with mineraloil and completely seal of the housing from the outside pressure using magnetic drive this design should handle almost as much as the other commercially availiable thrusters.
As this forum is quite new i will put out some links to stuff that might get things going.
Some thruster references from other ROV enthusiasts: (may save you a google search or two)
http://aquaticus.info/thrusters
http://www.rcgroups.com/forums/showthread.php?t=580739
http://www.cnczone.com/forums/rc_roboti ... seals.html
http://www.physicsforums.com/archive/in ... 81533.html
http://www.physicsforums.com/showthread.php?t=150247
commercially available thrusters is
http://www.tecnadyne.com/faqs.htm
http://www.deepseasystems.com/4000.htm
but soooo expensive...
Here is some interesting finds about underwater connections and other stuff you might want to check out for your design.
http://www.subconn.com/default.asp?objt ... ch&id=2451 - underwater ethernet connections through hull without comprimising the integrity of the chassis.
http://www.mtroniks.net/details1.asp/Pr ... an68.5.htm (built for model planes but i have read about some people trying it for underwater though).
http://www.aero-model.com/ - brushless motors for model planes. (to high rpm on most motors but if it was possible to gear down the axis with some worm gearing or such it could work)
Also do check out some of the FPV community when it comes to OSD and small camera tips.
http://www.decadenet.com/bob4/bob4.html - build your own On screen display with this OSD module
http://www.rangevideo.com
http://fpvpilot.com/default.aspx
And ofcourse the microprosessor Arduino is becoming an altime favorite so check out www.arduino.cc for Atmel PIC controller to run the electronics in your ROV. Using an ttl to RS-485 converter you can run serial link for 100meters or more through regular cheap cat5e TP cable. Check out the MAX485 chip for this.
I will post alot on this another time.
More on cameras on my other post in the cameraforum
