Props
Posted: Jul 30th, 2012, 2:53 am
by onibnasir
I am designing the ROV to goto 100ft. Should i use aluminium props or nylon props? And what difference does it make with either of them?
Re: Props
Posted: Jul 30th, 2012, 3:28 pm
by Rover
RC race boats that are turning the prop at high RPM will use an aluminum prop as they are a little stiffer. With our ROV's the motor RPM and ROV speed are slow enough that you can use the cheaper plastic props.
Check out http://www.funrcboats.com/ROV-Supplies.aspx
Jim
Re: Props
Posted: Jul 31st, 2012, 8:49 pm
Aluminum are stronger but are also much more expensive then plastic or nylon props. I've never had a problem with any of the plastic ones I use.
-Steve 8-)
