ROVer
Posted: Jul 17th, 2012, 1:12 am
A couple of years ago I saw a Video Ray ROV, and knew I had to build an ROV. The first prototype ROV we made had brushed motors inside o-ring sealed housing. We struggled with controlling current draw and trying to cram all of the electronics into a 12 inch long 3" diameter tube. That ROV got shelved, and The current ROV was born.
After a lot of debate and testing we:
- Kept the 3" diameter tube, but increased the tube from 12" to 16".
- Switched from brushed to brushless motors
- Running the motors wet (no housing)
- Added a wing to the ROV
The ROV control system was built around the ROV Asia control system. (I was able to get one before they shut down)
Currently we are feeding the ROV power from the surface. The tether is a 1/4" Flexzilla air hose. This hose is extremely flexible. The Flexzilla hose is advertised as being able to lay flat right after uncoil and remain flexible even when it has been completely frozen. So far our testing of the tether looks good. It also allows us to keep a slight air pressure inside the ROV.
In another post I will show the ROV electronics and surface control system.
