Mounting control boards inside PVC pipe
Posted: Jun 25th, 2012, 9:26 pm
Hi everybody,
I'm trying to put a PCB inside a piece of 4 inch PVC pipe. The board is about 3"x4", but only fits reliably in the 3" dimension. It is about 3/4 of an inch tall, due to a MOSFET for driving lights and a capacitor for filtering power. I'm thinking about putting another board of the same form factor to hold more electronics for sensors and whatnot on top of this. I'd like to mount this a little below the center of the pipe looking from the circular end, along with two ESCs for motor control. I'd like it to be fairly secure, to withstand rough handling ( I may send this with my little brother on a school trip, and the frame is a bit bulky), but I'm not sure what to use to keep it in place. I'd also like to be able to slide the whole kit and caboodle out of the pipe for maintenance/repairs/upgrades. What do you guys use to keep PCBs secure inside pipes? is there anything you would recommend I do?
Thanks,
Legoman132
Thanks,
Legoman132
