h bridge relay Wiring Help!
Posted: Jun 2nd, 2012, 2:00 am
by timothyalderson
I bought H bridge relays and Im trying to get them Wired. THe post are different from the examples and there is an extra post? Trying to figure it out
http://html.alldatasheet.com/html-pdf/3 ... 12-W1.html
Re: h bridge relay Wiring Help!
Posted: Jun 2nd, 2012, 8:49 am
by derelicte
are you saying the number of terminals and the layout on your relays don't match the datasheet?
Posted: Jun 3rd, 2012, 4:05 am
by timothyalderson
Yes, the diagram is wrong I think. I put power to one and tested it and no go. Has anyone messed with this relay? I tried wiring up the whole ROV and no dice. The motors don't turn and the camera is static. Any advice?
Posted: Jun 4th, 2012, 8:45 am
by derelicte
well, get out an ohmmeter and see if you can figure out which terminal is which. it shouldn't be that difficult.
Posted: Jun 5th, 2012, 12:00 am
by timothyalderson
I got it all worked out. The relay were weird. Post were vertical instead of horizontal.
