Power or Cat 5
Posted: Mar 22nd, 2012, 1:50 pm
by pacman411
Hi all
Just and idea I had bouncing around my head for some time
Since Cat 5 cable has 4 twisted pair is the a way of sending 12vdc 3 amp over one of the pair to power the system on the ROV, One pair for the vid and the other two pair for data and control of the ROV
Paul
Re: Power or Cat 5
Posted: Mar 23rd, 2012, 8:56 am
by derelicte
electrically that should work. however, are you running your thrusters off of the 12v, 3a pair? if so, you will probably find the voltage drop to be pretty high.
also, 3a isn't enough to run one thruster.
but if the 12v is just for cameras, controller, sensors, etc. then it should be fine, especially if they can tolerate running on slightly less than 12v.
Re: Power or Cat 5
Posted: Mar 27th, 2012, 11:23 am
Yeah, trying to send power over a cat5 for thrusters isn't very practical. I've done some tests which the results can be seen on this page
http://www.homebuiltrovs.com/howtotethe ... edrop.html remember the longer the tether the greater the voltage drop will be too.
Re: Power or Cat 5
Posted: Mar 27th, 2012, 2:36 pm
by ERIEWRECKDIVER
Well maybe I am crazy. But this is what I am doing.
I've been working with an Electrical Engineer friend of mine. He has convinced me that for what I am trying to do, I need to do the following.
1) Cat5E is going to be my control tether, to my onboard relays.
2) 12/2 is going to power my relays. This gives me the horsepower I need for my thrusters and lighting.
3) Plus my video cable.
Yes this makes for a thicker tether, that will create buoyancy issues that I will have to address. But because I won't have power loss, my thrusters and lighting won't be compromised. I will be able to run everything all at once, which may be necessary while dealing with currents.
Plus, my tether is becoming one of the most expensive parts of my system. But as my friend says. What good is it, if I can't get to where I want to go and see what I want to see?
