Hi All,
A few forum members have mentioned using a leak detection system within the pressure chamber. How is this done? Possibly by monitoring the internal pressure and humidity???
Regards
Max
leak detection
Re: leak detection
The leak detectors I've seen (and something I plan on using) is a pcb with copper etches on it. You can sort of make it out in this pic:
Re: leak detection
look on page 8 and 9 to see the leak detectors for this rov control system. they use the same concept.
http://rov-asia.com/document/RovMualFull.pdf
Dratsabylgu
Re: leak detection
http://makeprojects.com/Project/Water-L ... tor/1382/1
Forget the upper part ( the power supply ) and use the ROV power instead.
Place electronics in controller and place a sensor in the ROV
sensor can be 2 wires with ~ 1cm blank ends use some HMA (Hot melt adhesive) to secure on the ROV bottom
- Maximus Rumpas
Re: leak detection
Thanks to both of you,
I took a look at the detector recommended by Derelicte and sold by FloodStop, they sell additional/replacement units for $13.00.
- Staples Build Team
Re: leak detection
Found this and i guess it would be the easiest and most straight forward way to do a leak detector. Instead of a buzzer... have it as an input to the control system? How would one do that? Well let me just show you the video:
http://www.youtube.com/watch?v=Fg5NY4Uw ... e=g-user-u
Re: leak detection
to replace the buzzer I would recommend the use of a microcontroller, such as an arduino. See how many volts are coming from the positive wire that would normally go to the buzzer. If its less than like 5 volts you should be fine. If its more get a 5v regulator. Share the negative (ground) with the arduino. Done
