Page 1 of 2
Bilge Pump Motors VS Props
Posted: Jan 20th, 2012, 8:20 pm
by ERIEWRECKDIVER
Just ordered a 500 GPM "Rule" Bilge Pump Motor Cartridge from Amazon/The Price Pros for $24.99 including shipping and handling. I want to experiment with thrusters. Does anyone have a good supplier for props? PLUS any suggestions are always welcome.
Thanks,
B.C.
aka ERIEWRECKDIVER
t
Re: Bilge Pump Motors VS Props
Posted: Jan 21st, 2012, 5:14 am
by turtle
i ordered my propellers off ebay from hong kong there 56mm i got 5 of them for 6 pound think thats about 9$ and the adapters
form the motors to propellers was a couple of pound each. hobbyking are really good aswell.
adam
Posted: Jan 21st, 2012, 10:17 am
by ERIEWRECKDIVER
Thanks, I'll check this out.
Posted: Jan 21st, 2012, 10:33 am
by turtle
ERIEWRECKDIVER wrote:Thanks, I'll check this out.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... OC:GB:1123
this was the link, there 57mm not 56mm this was the price for 5 with post to the uk. i just had a look in my emails. but it will depend on what size tube your using if your ducting them like me. i have had to buy things to suit the size of other things.
adam
Subtotal: £5.05
Postage & packaging: £2.89
Total: £7.94
Posted: Jan 21st, 2012, 10:50 am
by ERIEWRECKDIVER
Thanks again. When I get my pump cartridge, I will have a better idea about shaft size and then I can start to experiment with props.
Posted: Jan 21st, 2012, 10:56 am
by turtle
ERIEWRECKDIVER wrote:Thanks again. When I get my pump cartridge, I will have a better idea about shaft size and then I can start to experiment with props.
no probs get some pics up when you get started.
adam
Posted: Jan 21st, 2012, 7:29 pm
by derelicte
I got my props from a local hobbytown usa. you can also get them from tower hobbies, etc.
see here:
http://homebuiltrovs.com/rovforum/viewt ... befc#p1751
Posted: Jan 25th, 2012, 8:29 pm
by ERIEWRECKDIVER
derelicte,
As my daughters would put it. YOU ARE THE BOMB.
I love why you built a ROV. Way to much fun. I bet your daughter thinks her daddy is the coolest.
Thanks for your info on props.
B.C.
aka ErieWreckDiver
Posted: Jan 26th, 2012, 8:54 am
by derelicte
thanks for the remarks and I'm glad I could help.
Posted: Jan 27th, 2012, 8:56 pm
by ERIEWRECKDIVER
So I just got my Rule 500 gph cartridge. Started to slide the impeller off. It popped off and scared the He__ out of me. LOL. So now I can measure the shaft diameter. The shaft is flat on one side like Steve said, so a set screw should work just fine. I plan on getting the props that were suggested RH and LH for duel drive motors for forward and reverse propulsion. But I just can't wait so I will be going to a local hobby shop tomorrow to see what they have for props.
But here is a big question. My motor says that it should have a 2.5 amp fuse. So seeing that I want to Reverse this motor. Do I put a fuse on both leads? One for Forward and one for Reverse??????
Thanks for any input.
ErieWreckDiver
