floating cable
Posted: Jan 18th, 2012, 11:52 am
by turtle
hi has anyone found a floating multicore cable at a reasonable price. i was going to use floating rope but it seems huge when the put the wire in it.
adam
Re: floating cable
Posted: Jan 19th, 2012, 12:16 pm
by turtle
has anyone tryed stripping a multicore cat5 cable and putting it inside some silicon tube to see if it will float. i was thinking of injecting silicon about every meter to make an air pocket and see if it floats.
adam
Re: floating cable
Posted: Jan 19th, 2012, 12:26 pm
by shaneb24
I used 250ft ¾ hollow braid polypropylene rope and Intech Range Bucket with 48 Balls with a double pair of cat 5. I took the jacket off the cat 5 to make it lighter.
Id give it a 7 out of 10 for performance but price point was 10 out of 10
Re: floating cable
Posted: Jan 19th, 2012, 2:07 pm
by Silver dollar
turtle wrote:has anyone tryed stripping a multicore cat5 cable and putting it inside some silicon tube to see if it will float. i was thinking of injecting silicon about every meter to make an air pocket and see if it floats.
adam
The pockets will implode by the water pressure on deeper water. So the floating effect will decrease the deeper you go. The air pockets must be rigid.
Re: floating cable
Posted: Jan 21st, 2012, 5:20 am
by turtle
shaneb24
ive done a few tests and the ropes soaking wet when i pull it out the water thats why iam trying not to use rope if i can.
Silver dollar
didnt think of that thanks.
theres got to be something out there thats suitable for what we need cheap.
adam
