on board transducer with topside display
Posted: Jan 17th, 2012, 12:52 am
I've been running around the bays for a couple of days using my new Lowrance StructureScan system (side scan sonar). One thing I've quickly learned is how hard it can be to get on top of a specific spot and then stay there. Once you drift off it takes some work to find the same location, even with GPS. One of the things I'd want to do with an ROV is send it down to investigate interesting structures found with my sonar. The visibility in the bays around here is good - for a bay! But not good for seeing much more than a few feet away.
This got me thinking about these new high resolution sonar systems and how nice it would be to have a forward facing sonar (they have them for big boats!). I almost collided with a sunken 40 foot sail boat Sunday. It was within two feet of the surface at the highest point. It was first spotted on the side sonar, but my downscan had showed it the highest part that I went over to be about 8 feet down. I did notice long shadows and should have heeded that better. Going back towards it to get a better scan, my wife suddenly yelled a warning and I stopped the boat immediately. It was HUGE and shallow!! All of this is on video around 3:20 at http://www.youtube.com/watch?v=e5ocaqkz ... ture=inbox
Anyway it would be useful to have at least a basic echo display on the ROV. I envision it being forward facing, but mounted on a swivel. The movement pace would be not unlike a typewriter. A 'slow' scan from left to right (typing) and then a quick return to the start position. Rinse. Repeat! Timed correctly, the information on the display would form a sort of forward picture ahead of the ROV. Yes it would be a scrolling picture, with the fast return making a distorted break between each slow scan pass. Most imporantly, distance measurement would be accurate. In theory this could be useful in navigating to a large enough target such as a sunken boat.
I know HumminBird specs allow a 50 foot extension on many of their units. Who knows what the ultimate limit would be. I know the low rez units only have a couple of wires and a shield. Downscan units have a lot more wires. The ultimate would be to use a Lowrance downscan unit, but that would set you back $300 at least. If the cable can't be extended, well there's always putting the display inside the ROV and pointing another camera at it. Best avoided though!
Sorry for my off the deep end thoughts, but they keep me going!
This is the image we got of the boat:
