Controlling Gripper Closure
Posted: Nov 4th, 2011, 7:10 pm
I've been trying to design a manipulator for my project, but cannot figure out how to control closing the gripper. I originally planned to use a standard DC motor and some worm gears.
What would happen if I inadvertently tried to over-rotate the gripper mechanism once it was fully open or closed? If the gears were strong enough to sustain the force would the motor burn up applying a constant load without the shaft spinning?
I will have kids using the ROV consistently and am worried that the gripper could be damaged. I looked into servos, but do not want to use a computer for control. Is there anyway to control servos without a computer? Ideally I'd want to use a joystick for arm movement and buttons for open and closed.
