Thanks for the comments.
I'll post pics of the other frames under My Meager Machine post, oldest frame to newest.
1st frame was to big and bulky for the motors I'm using, I modeled this frame after the Hornet
http://my.fit.edu/~swood/ROV_2.html. The motors are ducted fans from Tower Hobbies
http://www3.towerhobbies.com/cgi-bin/wt ... LXSBF7&P=7.
These motors were cheap and had the duct and blades all ready to go just had to built a motor mount. The bilge pumps around here all seemed to be kind of expensive and I didn't really know where to start with picking the right props. More blades means less cavitation as well and these fans have 6 blades. If the motors go out I can always put brushless motors in fairly easily.
The ducted fans have brushed motors running right in the water. No problems at all. I run them each for a min or two to dry them when the dive is done to prevent corroding. RC hobbyists run these brushed motors in water to break them in.
I'm running 12v down 100' tether and getting around 5v voltage drop. The motors can run up to around 10v.
2nd frame was to hard to balance. It wanted to flip upside down and it seemed like no matter where I put weight I couldn't make it right, Not to mention control was something of a joke.
3rd frame was better but the cup I was using didn't allow room for the dive motor to be mounted in the middle of the ROV, so the ROV would tip up and down and not dive level. And the cup was just a plastic water bottle which couldn't handle any real depth. I dropped it down to 82' and when i brought it up
4th (this design) has a mirror quality to it. The back cup with relays in it (toilet floor drain 2" abs plastic pipe, cap, lexan window, and riser ring that matches the drain) Then the dive motor then the front cup, same as above with camera in it. Control, balance, and weight are much easier to manipulate and tweak.
I am in the process of redoing the lights. This is the fourth time for the lights as well. Between voltage drop and leaking enclosures the lights have also been a big challenge. I'm putting the lights on their own battery power so no dimming with voltage drop. They are cheap Harbor Freight 9 led flashlights
($2.50 for 2) hacked and stuffed into a slip pvc coupling 3/4" and 1 1/4" cap on the end. They fit perfectly with an O ring and the rubber grommet inside the coupling and a lexan window. Sickaflex sealing the wire entries. I'm feeling pretty confident in this setup.
Trying to find the right combination of thrust, mass, weight, buoyancy, balance and power is the real trick I think.
Deakel
