vocabulary
Posted: Jul 26th, 2011, 5:06 pm
Hi all I’m posting this as a general vocabulary section so that anyone new (or not) can have easy access to the vocab of our hobby, and so we all can "speak the same language". Feel free to add to this section if i miss anything (and i know i will) and to make any corrections.
Homebuilt
Made at home or made by hand from parts that are not specifically manufactured for the applied use. I.e. bilge pump thrusters. Not a kit or fully assembled unit.
DIY
Do it yourself.
ROV
Remotely operated vehicle a robot that requires input from an operator.
AUV
An autonomous underwater vehicle (AUV) is a robot which travels underwater without requiring input from an operator.
Control tether
usually just referred to as the tether is a set or group of wires (i.e. cat5 Ethernet cable)that go from a control unit on the surface to the rov used to transmit control signals and or power.
Safety tether
a cable or rope used to retreive the rov incase of snagging or power falure. also used to lift the rov out of the water without putting stress on the control teather.
Topside
in the boat or on shore, on the surface.
Subside
Underwater or on the rov.
controller
can be an analog or digital control box, or a program in a computer, used to interact with the rov. they can be a single unit or several different units, that connects directly to the tether or to an interface box topside.
Manipulator
a movable or fixed arm with a grabbing device on the end allowing retrieval and or manipulation of objects subside. can be simple fixed claws that open and close to highly articulated multi-jointed arms
Thrusters
Motors that propel the rov/uav through the water.
Bilge pump
A motor in a sealed housing that is meant to pump water out of a boats hull. Bilge pumps are commonly used and or modified to be an rov/auv thruster by diy’ers
Brushed motor
A motor that has a set of brushes inside of it the make contact with the motor to make it function.(I know this is a very simple explanation).
Brushless motor
A motor that doesn’t use a brush set to operate the motor, instead it uses magnetic force to keep the motor functioning.
ESC
Electronic speed controller. Used with brushless motors
Potting
Placing a sensitive electrical device in a container and filling it with a waterproofing and sealing material such as epoxy, wax, or silicone so it can function underwater.
Ballast tanks
Hollow tanks that add or subtract buoyancy to a rov/auv. The tanks that have an adjustable system that allows them to be filled or emptied.(thanks Pilikia)
Buoyancy tanks
tanks that are perminantly filled with air to give + Buoyancy.(thanks Pilikia)
Ballast weights
Heavy objects such as lead weights that help to balance the buoyancy.
Buoyancy
How much the rov or tether wants to float or sink in the water. Buoyancy can be made negative and the rov will try to sink, positive and it will try to float, or neutral and it will hover in the water.
Floats
Any material that floats and is used to adjust the buoyancy of the rov or tether.
Dredge
A tool used to remove sediment and deposit it away from the worksite.
Newb
an individual who has no idea what the heck he's doing, but is still completely obsessed with ROVs. (thanks ImmatureAthlete
Homebuilt
DIY
Do it yourself.
ROV
AUV
Control tether
Safety tether
Topside
Subside
controller
Manipulator
Thrusters
Bilge pump
Brushed motor
Brushless motor
ESC
Potting
Ballast tanks
Buoyancy tanks
Ballast weights
Buoyancy
Floats
Dredge
Newb
