Phidgets SBC for total ROV control
Posted: Nov 16th, 2010, 1:13 am
First here is a list of the functions I want in my ROV then I'll go into my thoughts on the Phidget boards.
Movement: This will consume 9-10 outputs
LEFT-RIGHT
FORWARD-BACKWARD
UP-DOWN
YAW
CLAW ARM
Video:
One camera minimum 640x480 frames @ 15fps
Two cameras preferred. Frame rate can stay at 15fps for less bandwidth.
Sensors:
Water sensor for flood indication.
Compass for ROV direction indication
Sonar for depth and distance from bottom
Other sensors
Phidget's, 1070 SBC
SBC is Single Board Computer.
I have been looking at this board and ones like it for several reasons. Here are some of the issues and maybe you can provide your thoughts.
I need many I/O's for ROV control and sensors.
I need video feed back to topside.
I would like to record the video feed.
I need 220' depth
Expandability for other applications.
Just for the fun of it.
Wires: I could use the basic relay control which I think I could make work over a 200' cable and composite video that would need a coax cable most likely. All this would mean a hefty custom cable and limited control and capability.
USB: USB would be great but it falls out of bed after about 60' and I would need USB 2.0 speeds for the video. The USB to Ethernet extenders may work but it take a good quality one to do it to 200' and that will set you back $300 plus.
RS485 will go the distance but It wont handle the video on the same cable and you end up with two different types of cables to deal with and software.
Ethernet: This looks to be the best choice for both distance and capability, but this also means software which I don't have much experience with. The cable is not too costly compared with the other options.
Fiber optics: This is the best choice by far but the cost will undoubtedly be too much to swallow. Do you know of an inexpensive way to use it? The only way I can think of is the use a USB to fiber then back to USB.
looking at the capability of the Phidget SBC along with the 8/8/8 I/O board and using Ethernet cable to the top side PC, I think this could be my choice. What do you guys think?
LEFT-RIGHT
FORWARD-BACKWARD
UP-DOWN
YAW
CLAW ARM
Video:
Sensors:
Other sensors
Phidget's, 1070 SBC
I need 220' depth
