I'm new! ROV ideas
Posted: Jun 27th, 2011, 11:19 am
Hi, I'm new to the forum but have been working on building an ROV for a couple of years now.....ever since my son lost his waterproof camera off a dock and I vowed to retrieve it!!
I've done lot's and lots of thinking about solutions to problems, read what others have done and formulated some of my own ideas. Here's what I've come up with:
2 Veleman 2 wire 10 channel boards for 20 total control channels- built and working
3 thrusters with 1/4" oil seals - built and working
camera, Panasonic color security camera and enclosure - built and working
tether:
I've decided to use a tube with just the stranded cat6 wires run inside (2 pair-control, 1 pair-video using baluns, 1 pair-120v power). I've bought 100' of 1/4" ID (3/8" OD) polyurethane air hose for the tubing, if it all works well I'll eventualy add more length. I've experimented with the tubing and have found that 4 pair of 24ga wire is positively bouyant and 3 pair of 24 ga and 1 pair of 20 ga is very slightly negative....what's better, slightly + or _? I'm going to pressurize the tubing with a small 12v air compressor at the surface and let the air bleed through a check valve at the ROV. This will serve three purposes....
1-pressure compensate the components of the ROV to minimize water leakage (I'll connect everything with very small diameter tubing...even the thrusters)
2-Use a pressure gauge on the surface and use it for the depth reading
3-I think the bubbles which are vented from the ROV will help locate the ROV's position from the surface.
I found 100' Dewalt 1/4" poly air hose online for $29 plus shipping from Home Depot online store. It's yellow too!!
control:
2 joysticks and various switches...all bought but not assembled
monitor:
7" lcd tv with inputs...bought ($24 from Newegg.com last week)
camera tilt:
motors and gears bought but not assembled yet
about all I need to buy at this point is a small air compressor and a tether hose reel ($29 from Harbor Freight). I have a 1000w voltage inverter to supply 120V to the ROV along with a GFCI for safety and the battery. I'm thinking of using an old laptop charger (4a?) to keep an onboard battery (12v 7a) charged)
I'm going to get focused on the project within the next week or so as I have a self imposed deadline of August.
This system is a simple no frills project so I've kept the computer out of it on purpose...I'm using the KISS theory! (keep it simple stupid)
Once I get this all up and running I'm going to add an arm with a grabber.....that's what all the other control channels are for.
So, what do you all think? Let me know.
Bill
tether:
control:
monitor:
camera tilt:
Bill
