ROSEV - The Final Design
Posted: Jun 27th, 2011, 6:53 am
Ok, I have posted a few ideas however I have now found one which I like and I can finish without hitting brick walls such as delivery of products (as I live on a small island in the English Channel this is a big issue as we don't have big hardware stores as America does).
I have done a bit on the actual construction with the main bit that I've done so far being the control panel that I have designed to "plug and play".
I am building a ROSEV (Remotely Operated Shallow Exploration Vehicle) that I shall test using a ten metre tether then if all goes to plan I shall extend the tether to get it to a decent distance from the coastline.
The control panel is all I have so far so I shall give a quick explanation as I feel it is something different to what people are currently using and I would like opinions. The rest is pretty much like what others have.
The "Universal" control panel has been designed to allow for a "plug and play" style input. You have the basic set of control however unlike other control panels where they are directly linked to the motors and lights e.t.c. you shall have banana plugs or similar and you screw the lines into the panel.
The monitor is pre-mounted with an RCA connection so all you do is plug it in and turn it on, all power is provided by the same method, plug the battery in and turn the power on. The power goes through the panel and through the connections to the ROV. Once you have finished you turn it off, disconnect the power lines and then disconnect the tether from each of the ports. This allows you to take the control panel and use it with any of the standard (for me) connections that I have on any ROV I am planning on building.
What do you guys think of the panel idea?
