Using magnetic drive pumps
Posted: May 25th, 2011, 10:37 am
Hey everyone -
I was wondering if anyone has experimented with the idea of using magnetic drive pumps to use as thrusters. My current job is to maintain aquariums for a Maritime Center, so I frequently work with pumps designed for aquarium use that are submersible magnetic drive pumps that use a magnetic impeller that drops into a water tight housing. I know most of these pumps run off of AC but I was wondering if anyone has thought of using a 12 volt DC pump that is built the same way. Magnetic drive pumps essentially use a magnetic coupling right?
While im on the subject of thrusters does anyone know the shaft diameter of the mayfair 500gph replacement cartridge?
