USB doesnt work over 50'. any ideas?
Originally my plan was to run 2 USB connections over a 50' cat5e Ethernet cable (1 for control, 1 for webcam). Problem is I tryed it and it doesn't work. So now I need ideas on how to get webcam and control data to and from the ROV. I was thinking of using Ethernet and a switch in the ROV, but for that I'd have to get a ethernet shield for my arduino, a hub, and an IP camera. Any cheaper solutions you guys can think of?
Re: USB doesnt work over 50'. any ideas?
RCA to AV is what I am using, it is working fine at the moment however the only issue is it requires a camera with an AV output.
As for power, what everyone else is doing is connecting it to a car battery (or similar) and running it from that. As I have answered in another post a USB port doesn't provide enough power e.t.c. to get it over long distances, at short it only just supplies enough power but with voltage drop and a bad connection at the start it isn't the best method.
the usb would just be for data, no power. power would be supplied by a SLA battery or a 12AWG wire. I want to do somehting with higher res than RCA, but i might have to settle if there no other feasible option.
you can use adapters, that can transmit the usb data over a cat 5 ethernet cable, up to 150 feet, I've using one at the moment that's 30m, 90 feet.
Adapters are something like $15 off ebay
Regards
Martin
Regards
Martin
Not finding what your finding because all I'm finding is ethernet to USB (aka what you'd use to get internet to your computer via a USB connection).lostcaggy wrote:you can use adapters, that can transmit the usb data over a cat 5 ethernet cable, up to 150 feet, I've using one at the moment that's 30m, 90 feet.
Regards
Martin
They're usually called USB extenders or USB over CAT5. It sends the USB signal over ethernet wire.
Here's an example of one: http://www.monoprice.com/products/produ ... 1&format=2
Hope it helps![Smile :)](./images/smilies/icon_e_smile.gif)
Hope it helps
Actually I came up with another idea:
instead of
do:
instead of
Code: Select all
On Boat | Cables | on sub
Computer ----| > USB > cat5 > USB > | arduino > motor controllers data
\---| > USB > cat5 > USB > | webcam
12v power ---|-------------------------| motor controllers power
Code: Select all
On boat | Cables | On sub
Computer > USB > Arduino > 8 wires (6 data, GND, +5v (not needed))> | cat5 | > 8 wires > motor controllers data
Computer < RCA to USB converter ----------------------------------< | RCA video | < camera (not webcam) video out
12v power -----------------------------------------------------------|------------|-- motor controller/camera power
So you are planning to have the arduino control the thruster's using motor controllers, as opposed to relays, if I am looking at this correctly. Do you have to worry about loss of signal with the arduino over longer distances, or is this not an issue?
What camera will you be using? Looks very nice overall.
I've implemented your first idea nearly,
shore/boat
computer - usb extender -- cat 5 - - ROV usb extender - Arduino - ESC to 4 motor + OSD and digital compass
computer - CCTV coax and psu for camera - ROV board camera
onboard batteries for motors
seperate battery for Arduino / osd and digital compass
Martin
shore/boat
Martin
Yes, I'm using motor controllers not relays. They are simpler to wire. As for the signal loss I'll have enough power, and its just gunna be 2 on/off signals per motor (00/11 stop, 01 forward, 10 backwards) which require no timing, so as long as I get a little bit of power I'm fine. (I'm using 5206 H bridges).thegadgetguy wrote:So you are planning to have the arduino control the thruster's using motor controllers, as opposed to relays, if I am looking at this correctly. Do you have to worry about loss of signal with the arduino over longer distances, or is this not an issue?
As for the camera, I was thinking something along the lines of http://www.sparkfun.com/products/8739.
I was thinking about doing something like that, but I'm worried about the USB signal over 50'. I may have to use ethernet and and ethernet shield if I want the arduino down on the ROV for sensors and whatnot.lostcaggy wrote:I've implemented your first idea nearly,
shore/boat
Martin
EDIT: oh, and the quotes tags dont seem to be working
