thickness of poly carbonate to withstand 45 psi if it is 90mm by 90mm
Curlyfries36
thickness of poly carbonate sheet required to withstand 45 psi if it is a 90mm by 90mm circle supported by its edges thanks in advance and could I be shown any calculations to do this or tutorial's for the calculations that would be greatly appreciated
