asking for possibility of ROV
Electronics
Hey guys, Im starting a new project ROV for usage in sea or oceans so i wondering asking if I can put in the frame only thrusters and camera .and the electronics components (raspberry pi ,ESC ..)if I can put them up near the control panel and the camera screen . So in the end I want to create an ROV with only thrusters , camera underwater and the microcontrollers and all the canister components up behind the control panel
asesorplaza1
Re: asking for possibility of ROV
Good evening from Spain.
you can build your ROV as you like. It is not essential to put a thousand sensors. If you put only the engines and the video camera, you will have an ROV, and if you put a lot of sensors, you will have a more complicated ROV to build and program.
Greetings
Greetings
